Skeg broken
I broke an 1"1/4" of the skeg of my 8 hp Honda kicker, should I get it fixed or install a skeg protector overtop , if they even make one that small . Is it even going to make any difference having it missing on this little motor ?
thatone123
Banned
Yes, someone ???? could make a mint selling small skegs in the US. Australia has some but shipping kills the deal for me. They can be welded for not too bad of a price I have been told.
robert graham
Seems like the skeg on a kicker motor can't be all that important.....a welding shop can weld a 1/4 inch plate there and you can file/grind/paint to your satisfaction.....
Alumarine
The skeg is there to sometimes protect the prop when hitting rocks.
They never seems to help me.
I have two motors with broken skegs and unless they are mostly gone I leave it.
I doubt if you will notice that it's missing.
Thank you all for the input , I can see looking at it now that the prop is now the lowest point and that won't be good in the shallow water . I may just fabricate a skeg protector out of aluminium flat stock so my prop is a little more protected.
My vote, if it bothers you, get it welded. $35-50 for prep and weld
Well this is all I could come up with , 1/8" aluminium folded around the skeg stub.
Sea Rider
Was the injury done while the motor was running at speed with the swivel bracket in locked position ?
Happy Boating
No it was in my driveway , I was trying to straighten it out a bit and it snapped off , someone had drilled a hole in it and it snapped off at the hole . I should have left well enough alone😕
harringtondav
Kicker motor...probably OK to run it as is. It's there to provide prop protection and some rudder/steering benefit. Prop shops fix these every day.
