Siren
postal33951
Hello. I have aq 125hp force engine. On start up it is fine then after maybe 2 minutes or so the loud siren comes on and i have to shut the motor down to silence the noise. I have changed the impeller and am trying to figure why the siren still comes on. Can anyone help me Thanks
sidenberg
Re: Siren
The motor must be overheating. Are you getting the proper water flow?
Mark42
Re: Siren
Check the thermostat. They go bad and can be stuck closed, causing overheating, or just open too slowly or not enough to fully cool the motor.
postal33951
Re: Siren
Thanks for the reply but where would I find the thermostat in the Force 125hp.
postal33951
Re: Siren
I am not sure for I do have the ears attached and the water is free flowing well.
sidenberg
Re: Siren
I would suggest you purchase the Clymers Force Manual and read it to educate yourself. That manual combined with this forum should enable you to fix anything on your Force.
