Simple tricks for speedometer malfunction?
ildoc
The speedometer on my 1996 Mercruiser 5.7L with Alpha One Gen 2 drive operates poorly. It does register, but inconsistently and at least 15 MPH below actual speed. Since I'm fairly inexperienced, are there any easy things I can do to fix it?
ildoc
Re: Simple tricks for speedometer malfunction?
No help?
Manipulator
Mine does the same thing. Any help would be nice.
tommays
about the only thing you can do is be sure the hole in the drive is clear<br /><br />you can blow out the line from the speedo back and be sure the tubeing is not kinked<br /><br /><br />for the most part the speedos are of very low quality <br /><br /> the good ones like airguide speedometers work very well but they went out of Business<br /><br />tommays
Manipulator
Thanks Tom. I guess I will have to go the GPS route.
Doug Durako
You have something clogging the tube. Disconnect and blow it out from one end, and then the other end. Royal pain in the a$$ those speedo tubes.<br />Search this post for hundreds of entries on this topic.
sea wolf
Replace the pitot.
Silvertip
Replace the whole unit with a paddle wheel speedo.
wvit100
Quit looking at it.
Manipulator
Are there any other speedos out there that use new technology?
Bob_VT
Yes they are called GPS units. Higher end boats have them built in dash. I carry my handheld on my dash.<br /><br />Bob
ildoc
Originally posted by Bob_VT:<br /> Yes they are called GPS units. Higher end boats have them built in dash. I carry my handheld on my dash.<br /><br />Bob
What does a simple handheld model cost, and what's a good brand?
ildoc
Originally posted by ddboater:<br /> You have something clogging the tube. Disconnect and blow it out from one end, and then the other end. Royal pain in the a$$ those speedo tubes.<br />Search this post for hundreds of entries on this topic.
Where can I get a manual to show me how to do this? And difficult is the procedure?
