hwsiii
- Jan 25, 2009
- 2,639
Silver, I found your boat to have a base weight of 620 pounds and with an allup weight of about 1,500 pounds, the motor appears to have a recommended WOT range of 4,500 to 5,500 RPM and a gear ratio of 2.42:1. If this is wrong my numbers will be wrong as well. You will want a 17" Pitch prop but you will not attain maximum RPM but you will be in the maximum upper recommended RPM. Here are my numbers.
Boat and Motor
Prop Picker
H
Boat and Motor
Prop Picker
H
