Silly Volvo Penta DuoProp Questions...
WillyBWright
Where do I drain the gearlube? Do I have to yank the props like a Bravo? Do I need a special wrench for the forward prop?
bruceb58
Re: Silly Volvo Penta DuoProp Questions...
You pull the front prop with a special wrench. Drain is at the bottom after you pull the prop.
WillyBWright
That's what I was afraid of. ;)
Many thanks! :)
Don S
Also depends on which DP you have. The older 290 style had the drain plug in the housing like a Merc, the SX style DP-S has the drain plug behind the fwd prop.
