Re: Silly question? Water pressure help needed.
My old girl is getting a new water pressure gauge this weekend for several reasons. I'm having overheat issues and the boat has never had one. I will be checking pressure once the gauge is in. My question is: When running an engine on a hose with muffs, does that impact the water pressure reading? Or will it give me a higher than normal pressure. My tap runs at 45psi. It seems I should know the answer but I can't get my brain to work.
The muffs spring away from the LU at about 2 psi, so they won't overpressure anything. They probably will not supply all the water the engine would want at high rpm's, so the pressure would be low. You're risking catastrophic runaway to rev it up high with no load anyway, so don't try it.
Should be able to see if pressure is normal at idle and off idle. You won't gain anything by setting up a drum. If you had a real test tank and test wheel (loads the motor) then you'd have something worthwhile.
See if it's normal at idle, then take it to a lake.
BTW, the impeller will take a set and lose efficiency over the winter. That's your problem. Check the water pump and change the impeller and any other parts that need changing. Look especially at the base plate and the inside top of the housing. Grooves are bad.
As a routine, check and/or change the LU lube each fall before storage, drop the LU and change the impeller in the spring.
hope it helps
John
