Signal level of ignition driver blue lead.
WoodOnWater
Hi all,
I am trying to get a Beede tach to function with my '73 Thunderbolt 500. I am not getting it to register through the tach lead. I believe that the Beede tach needs at least an 8v signal to register. I would think that the signal strength at the switch box where the tan and blue wires attach would be 12v though it is possible that the value would be otherwise. Most likely the blue lead controls the ignition sequence. The tan pulls the signal for the tach and goes to ground when the key is switched to OFF, killing the engine.
Does anyone know what the controling voltage of the blue Ignition Driver lead is?
Faztbullet
Re: Signal level of ignition driver blue lead.
The blue is the HS side of ignition and will carry 20+ volts. The 50hp with ignition driver used a special tach or regular tach with module to operate. Your best bet is to modify wiring and bring signal source off rectifier. The original tach was a Mercury A-91-45294A3 or 91-4816A6 and module 52552A3 .
http://www.ebay.com/itm/52552A-3-TA..._Accessories_Gear&vxp=mtr&hash=item43a9f77f7a
WoodOnWater
Thanks, Fazt,
Two questions:
What does the module do to the tach signal?
Where would you pull the signal off of the rectifier? 12v output or off of the stator input to the rectifier? How many pulses per revolution?
Well, maybe four questions.
Faztbullet
Balances and clips voltage from what I remember.....
Stator input to rectifier......
Should be 12 pole...............
You will need to modify wiring on internal harness so tan is not jumped to brn if you go with rectifier imput
WoodOnWater
Nice. I hadn't thought about splitting the jumpered wire.
WoodOnWater
Tach is up and running. I'll be splitting out the jumpered wires. It was reading 1000 rpm at idle. Seems a touch on the high side. No matter. It's working and now it's a matter of dip switch setting to get it indicating properly. Your information was the key. Thanks.
Here is my project.
http://www.boatdesign.net/forums/powerboats/putting-all-together-15377-2.html
Post #13 was some photos.
