mark_gober
- Jan 12, 2009
- 76
Hey everyone,
I've got a question that may require some old salt knowledge. I have in my possession, three 1953 model Mercury Mk-20 motors. One of them is essentially a parts motor, one freely spins(although I haven't attempted to make it run yet), and the third is siezed up, but otherwised complete. I figured I'd work on the seized up motor to gain knowledge on the motor so that I can definitely get the freely spinning motor working. Having said that, I'd love to get two motors running so I'm asking questions about freeing up a seized motor.
It occured to me that I might be able to utilize an air compressor to perform this task. I figured that if it has a 3" piston (just a guess on diameter) that with 150 psi, I could generate around 1100 lbs of pressure. The problem that I had was being able to construct a fitting to go from air hose to spark plug fitting. Anyone ever had any luck performing this task?
In researching possible suggestions, I came across a seemingly simple, yet genius solution that might work. Why couldn't I spray either starter spray or carb cleaner or any other extremely flammable spray into the spark plug hole, screw the spark plug into it and then supply a spark to the sparkplug from another source. It might be me, but man that sounds like a smart idea.
If anyone else has any ideas on freeing this motor up, I'd love to hear them. The motor was my grandfathers and so it has some sentimental value and I'd love to get it working.
Mark
Mark
