Sierra18-7824-replacement
hrf1
Volvo Penta(350 chevy block?) 1997 4.3L has a Sierra 18-7824 filter. is there a filter (quality) replacement. I have seen varied replacements on boards.
Wix 51069 / 51061
Napa 1069
Pur L20049 / L34631 /L24736
Fram PH 30
Thre are even more listed in sites. Is the Sierra 18-7824 that common that you can use many other filter? Is there a filter that I can by in a Car Parts store with better specs.
Info Appreciated
Re: Sierra18-7824-replacement
Ayuh,... Which is it,..?? they take different oil filters....
The 4.3l uses Napa 1036....
Don S
On a 4.3L Mercruiser, you have a different filter for the remote mounted filter from the block mounted filter.
6meter
A 350 Chevy block is not a 4.3L. 350 is an 8cyl 5.7L. Two different blocks and oil filters.
hrf1
It's a 4.3gl volvo penta . I have a new block, but thought it was chevy??
BRG25
It is a GM block....but not a 350 GM block
