Side Steer converting to Center Steer
Ducksmasher
Ive got a 1992 60hp jhonson tracker pro, that came in the aluminum boat with side steerin.. i found a nice aluminum center console with switches and radio hole and i bought it. so now i need some parts to make this thing work... the first thing i noticed is i need is a longer steering cable. and longer throttle cables... so i started looking at the control box, and it is sort of backwards for the setup i would want. the tilt is on the right side and the box mounts on the right hand side... so i would need a control box that mounts to the left side, and has a tilt trim switch facing towards the left to properly mount it to the side of my console and use my right hand??? hrmm is there a control box that i might beable to use or retrofit to this motor? heh i already gave away the side steer console, so i have to make this work before duck season! argh what i do just for a radio in the boat.
