Side port/window seals
Status
Not open for further replies.
j_k_bisson
I have a 1991 Bayliner Trophy walkaround 2002 model. Right now everytime it rains water comes in thru the window seal joint. I would like to replace the rubber o-ring like material in the windows.
Anyone know where you can buy this stuff? Nothing special about it. Just mine is old and not doing it's job anymore. So it needs to be replaced. The window is still in good shape.
Cap’n Ray
Re: Side port/window seals
Is the water coming in from the window seal itself, or where the frame meets the hull? If it's the frame, you need marine sealant, if it's the window, check with your dealer and see if the seals are even available anymore. Best of luck to ya!
j_k_bisson
Over the poast winter the windows where removed and resealed. It is not leaking in the frame. It is the seal It's been compressed for years and not doing it's job any more. I called the dealer and they can not get them . but I did fin a plce on line that sells it bulk roll. But I only need 5 ft of this stuff. Wondering if anyone has a place to get it by the foot.
Cap’n Ray
Thumbs up on the reseal over the winter. You might check with any local glass companies, if you have the dimensions of the seal, you might be able to match it up. Best of luck!
Status
