sick '91 Yam 225 TXR for sale N. Fl
Grayson
This motor has been giving me trouble for several months now and I'm tired of chasing gremlins. Two weeks ago it started skipping a cylinder while I was on a charter. The usual fixes had no affect so the Dr made a house call. The Yamaha mechanic diagnosed a bad head gasket (4 cylinders 100-102 lbs, 2 cylinders 88-89 lbs compression) I pulled the head on the weak side and found a perfect gasket, but two looser-than-should-be pistons.<br />I'm not going to spend the $ to rebuild this motor, and have purchased a 2001 SWSII 250. Not much on the 225 is compatible so rather than keep it for parts, I'm selling it complete. I recently replaced the trim motor, TPS, a fuel pump, water pump and thermostats. The carbs have been cleaned and are fine. Tilt/trim system is strong. I've never had a problem with the lower unit, but I'm keeping my prop. This motor also comes with its old but functional hydraulic steering system less the wheel.<br />I bought this motor on the boat 7 months ago and have no idea as to how many actual hours are on it. The motor was running (although roughly) when I took it off the boat 11/11/01 and is now inside a wharehouse in Apalachicola. This is a good candidate for rebuilding or as a spare if you already have one. I'm asking $1500 OBO for the whole package you come and get it. Email me at grayshep@yahoo.com for more details. You can go to : http://www.yamahaoutboardparts.com/wwwboard/ <br /> to look at some of my other postings concerning this motor<br /><br />Thanks<br />Grayson Shepard<br />St George Is Fl.
