Re: Shrink Wraps
hey Pointer,<br /><br />ah yes, nothing like the smell of burnt hair in the morn.
<br /><br />i lose a little armhair myself this time of year. usually when tucking and welding the bottom. but yeah, you gotta watch those pockets, that stuff'll blow right back at ya
make sure you get those folds nice and hot with some 4" down the seam. most guys don't weld them well enough and they're flapping open in a month or 2..<br /><br />sounds like your using a shrinkfast if ya got a sparkplug. almost got one this year to replace our dinosauric Protect-o-boat. we went with the Ripack, little cheaper. nice gun so far. i also use a Big Red with a custom extension to actually shrink. i only use the handgun for my bottom weld and the folds. then i break big red out. when it's calm i can do the shrinking part on like 40'ers in about 15 minutes. it comes with this thin, wimpy extension. i attached a telescoping metal wash pole to it and can get very high on the boats with it. i also use a 12' stepladder.<br /><br />and yeah, inside boat stuff can be hairy, be careful, not a very healthy thing i would assume. breathing propane in can't be healthy.
used to have to do it alot more before i had the extended big red. i would use my 3M battery powered, air supplied facemask so i wasn't breathing propane in.<br /><br />nowadays i rarely have to go inside, usually just a tad in the bridge. i just start at the highest point and go down. but if your shrinking a fair amount from the inside, yes, that lack of O2 line will get lower and lower. not much you can do other than start the gun up down by your feet and work quickly. when i used to have alot to do inside, one trick would be to take an ordinary boxfan in there to circulate the air around a little.<br /><br />wind is definitely the enemy of a shrinkwrapper. our yard starts blowing everday at 10am, with a nice lull right at sunset too...<br /><br />we get all our shrink, tape, etc from Mesco. they give us a much better deal than like Dr. Shrink or others. we generally get about 40 various rolls a year.
