DestinyEscape
- Feb 27, 2003
- 22
Hey Guys,<br /><br />Here's what I've got:<br /><br />1997 4.3LX Gen+ Mercruiser (Carbeureted) w/ Alpha One Stern Drive on a Marada 18' Fish/Ski Boat.<br /><br />The problem I'm having is this:<br /><br />Had the boat out on Memorial Day, and the starter stopped working. One of the girls that was on the boat with me went to shut-off the engine and turned the key the wrong way causing the starter to grind. When I went to restart the engine it made a clunk and then the starter just starting whining like it wasn't touching the flywheel anymore. I took the starter to a shop to have it re-built and it turns out there is a plastic gear inside the starter that was stripped. They said that this could be caused by what she did (engaging the starter with the engine running) or if the engine was seized. I put the starter back on and it did the same thing as before (clunk... and then just the motor whining). I turned the engine over by hand (with the spark plugs in), and it seemed to have normal resistance. I checked the flywheel to make sure that the outer gear ring had not seperated from the center and everything seems fine there.<br /><br />Currently, they are again rebuilding the starter for me, and tonight I am planning to pull the plugs and turn the engine over by hand to see if there is any water in the cylinders. I believe that this would be hydralock?<br /><br />Anyway, I was hoping someone might have run into this problem before. Any suggestions? Thanks in advance guys.<br /><br />CP
