TravisTraverser
- Apr 20, 2005
- 27
I just purchased a 1994 Larson Hampton 240MC. The shower sump had dirty water in it and does not appear to be draining anywhere. I cleaned out the sump, blew air into the "drain plug" and then filled it up with clean water, but it still does not drain. There is a shower sump switch just below the sink, but it does not appear to work (at least I cannot hear any noise when I turn it on), although there are wires routed from it towards the fuse panel.<br />Anyone have any ideas as to what to try next?<br />I also would like to know where this water drains to? The manufacturer could not verify if it drains into the bilge, or directly to the holding tank.<br />I does not appear that the floorboards in the main cabin are removeable, otherwise I could look into the bilge and verify what is happening.
