My question is about the Shower pump. <br />Whenever I used the shower, I had to turn the breaker on in order to get the pump started and it would run until I turned it off....I came to the conclusion that the float switch should regulate it on /off , so I removed the float switch, and found it to be out. However; after I removed the float switch, the breaker still activates the pump. It appears to be the original pump and wiring with three wires running to the pump/switch.<br /> I thought it should be only two with the switch breaking one of them ... being a shower pump novice, maybe I'm missing something.<br /> <br />1) Shouldn't your shower pump work automatically after turning on the breaker ?<br />2) Or do you have to turn off the breaker to cut the pump off and on?<br />3)Apparently one wire is the neutral. One is switched by the Breaker and the third is always hot.(which was connected to the switch.)<br /> <br /> <br />Thanks
