Re: Should trailer tires be rotated?
If the tires indicate an uneven wear pattern, rotating the tires may or may not help extend the life of the tire. Uneven wear on trailer tires would be indicative of a more serious problem, such as axle alignment, bent spindle, etc. On the otherhand, if the wear pattern shows no problems, I suppose you could rotate from side to side but I'm not sure what benefit you would get otherthan working up a sweat. Be that as it may, if it makes you feel more secure, do it. DuPont
