Re: should there be water coming out?
When i ride my 98 seadoo GTI, I don't notice any water coming out from this little hole on the front right. Is this where it should be coming out or some where else? Sorry no pics.
Hey y'all, the OP said "right front"... which I assume is from his riding position. If you remove the forward storage bin, you will find a hose that runs (is supposed to run) to your battery, under the seat. The battery has a little extention at one end and there's a slide on or barb connection point. It points down, so it is near impossible to just "see it" in the open.
I had a heck of a time trying to figure out why there was a hole and hose that didn't have anywhere to go... for the life of me, I tried to find its attachment purpose anywhere in the compartment. Then I found it in an online catalog with pictures.
I guess it is to vent any acid vapors instead of them adding to the other fumes.
Hope this helps!
