I am looking for a short or overvoltage that burned up the original warning horn in an evinrude remote control and damaged a new warning horn. I have discovered that the low oil sensor in the oil reservior has a constant 12v in it, regardless of whether the sensor's float is making contact or not. The temperature sensors have no voltage in the circuit because they don't make contact until there is a problem. I assume the low oil sensor should work the same way. Does anyone know if I'm right in assuming the low oil sensor has failed and is completing the circuit continuously, thereby damaging the warning horn and eventually blowing the engine's 20 amp fuse? Thanks for any input.<br /><br />Phildiver
