stoked not
- Jul 20, 2001
- 143
Guy's,<br /><br />I have a 1992 225 Johnson. I'm trying to isolate water intrusion in the lower unit. I just bought it used and noticed the problem during my test drive I was told that it was addressed with a new prop seal and it passed a pressure test. After my first run out on the water a had water in the lower unit.<br /><br />After dropping the lower unit and removing the water pump I noticed that the O ring seals directly under the the water pump where the drive shaft come out appears to be a possible source for intrusion. When I move the drive shaft it wobbles. <br /><br />Q: Should the drive shaft wobble.<br />Q: Can I buy a seal kit to cover all seals?<br />Q: Can anyone recommend a place to buy a service manual?
