Should outboard be sitting on transom top?
JackBronson
Have a friend who just got a late 80s Whaler with a late 90s Honda 90. The engine is of course bolted to the transom but it sits above the top of the transom. There is a good two inches of clearance between the motor and the transom top.
Should this be a source of concern? Or is this normal?
See the attached photo. Sorry it's rotated - its not on my device.
Thanks.
GA_Boater
That happens when the motor is raised to get the sweet spot for the best performance. No concern at all.
Watermann
^^^ exactly, I have a CMC TnT unit on the back of my boat that has nothing hanging over the transom with the motor bolted onto the unit. All the weight is supported by the 1/2" bolts.
