So I am trying to troubleshoot a fuel leak and I have came across some posts that contradict what everyone has told me since I have owned my boat (little over 2 years).
The engine is a 1990 Johnson GT200 V6 (with oil pump disabled- bought it that way). Is this an engine that needs to be ran dry every time I am finished using the boat, or just before long periods of storage? I was thinking of installing a valve right after the primer bulb that I could control the fuel supply with, but I have read that doing this will cause cylinders to run out of the gas/oil mixture before others, leaving them vulnerable to possible damage.
I too, am having the fuel leak from the bottom of the air silencer cover. The gasket has separated and will be replaced, but I think there are other issues at work contributing to the leak (Carb spitback, Leaf-plates). I am not sure if running the engine dry will help that problem at all.
Any advice?
Any advice?
