Should i remove side panels?
Swampfox88
boat is a 1436 tin.
I want to know if I remove the side panels out of the inside of my boat that are filled with foam. Do they affect anything?
The reason I would like to remove them is because it would free up some room about 3 inches on each side.
I am putting foam underneath the entire floor of the boat.
Thanks for any advice/opinions in advance. bare floor.jpgnew boat 4.jpgfloor boat.jpg
Grub54891
Re: Should i remove side panels?
Are you removing the foam too? On the sides like that it is probbally just for sound deadning.dont think it will bother it except for the soung. You can always put it back!
smokeonthewater
That foam is there to float the boat upright if swamped..... If you never swamp it removing the foam will make no difference.... if you swamp it with foam under the floor you will be more likely to capsize than if it were in the gunnels.... MANY boats have no foam at all... It's all up to you
As for the panels themselves, I can't tell from those tiny pics whether they are structural or not...
Grub54891
Ahh,didnt think of swamping/ capsizing! Good point.
rallyart
Foam floats, boats should float. I'm for keeping the foam there.
