I have a Merc MCM170 that I would not start even with spark and gas in cylinders. The problem is described in this thread. The replies there suggest I may need to rebuild the carb 'cause it's flooding my cylinders. Looks like the mixture is also too rich as the plugs are all blackened.<br /><br />The carb I have is a 2 bbl Mercarb. Is this something I can rebuild myself? So far I've replaced the waterpump and fixed up the tilt/trim pump motor, and I'm able to understand the Clymer manual's procedures. I was told that I shouldn't do this myself because I can't get the carburetor cleaner that the shops use to clean out the gum and varnish. Is this true? Should I attempt it myself and save some much needed $$? Thanks.<br /><br />tuan
