rick powell
- Aug 4, 2008
- 38
Have a Evinrude 200XP on a Ranger 390V boat, both 1987 models, Have been having trouble with idling and no low end power on take off. I took off carbs and rebuilt and put new Oring gasket on intake behind carbs, which someone had torn and had put back on with siicone. Engine sounds like it is running better on garden hose. My question is the engine has not got a jackplate and is in the lowest mounting holes. Should I raise the engine up to the highest holes? Also I'm running a Racker 14 1/2 X 24 3 blade prop and turning only 5000 Rpm's at w.o.t.. Should I try a different prop maybe a 14 1/2 X21 to get my Rpm's up and if so should I raise engine up with this prop also?
