nphilbro
- Dec 19, 2011
- 304
I have a 18" steel transom setback in the garage I'm seriously considering mounting. Originally it was on the back of a I/O to Outboard converted 17' Olympic. This sucker is heavy but incredibly strong. It looks a bit rough in the photo but it's only superficial and I'll sand and paint it right for saltwater.
I would like your opinions and experience on this
My estimate for this project is about 12 hours (I always try to fudge on the high end and make sure I have the time).
I have read so many advantages in doing this such as the prop is more efficient because it runs in calmer water farther back from the trailing edge of the hull, it's easier to trim because it makes the bow more buoyant, allows you to increase prop pitch due to efficiency for more top end or just plain better hole shot and torque with original prop, gets up on plane quicker.
If these advantages are real it would address issues issues I'm dealing with and give me more latitude in optimal tuning options.
The boat is 100% designed to handle big water and the previous owner was telling me recently about some big seas he navigated in it off Vancouver Island. I frequently see many other boats of similar design with variations of this same concept.
Right off the bat, I have some concern with the added forces of 60# plus torsion weight multiplier from the engine's new position. The boat is rated to 200hp which was approx 390# in 1980 but I know the new torsion load will exceed that. Spreading the reach of the additional lateral force on the transom will be easy enough using the solid stainless backplate reinforcement from inside the transom of the other boat and bolting into 2x4s, blocking them to strength points at the transom joints. An effective transom support jack system for trailer transport will be critical since even in the full upright position the motor will exert a lot of stress.
I'd have to move the steering cable access and possible replace the steering cable and control cables.
Boat is 19.5' fiberglass closed bow runabout
2000# base weight
1740# motor and gear capacity
315# 140hp Johnson outboard
Transom setback distance is 18"
1" rise at extension but I can modify that up or down as needed.
Feedback appreciated.
Some pics here.
2000# base weight
Some pics here.
