I recently changed the motor in my Formula 252SS from a Mercruiser 7.2(454) to a 383 Stroker. Similar horsepower, less torque.
When I went to water test the boat No Pickup at all.
I changed the props from 26 pitch to 22 pitch which improved holeshot significantly.
Problem is that wide open throttle rpm is still only 4650. Spec on engine is 4800-5200RPM.
I am running a Bravo 3 with a 1.81:1 gear ratio.
Should I change the gear ratio on the Bravo Three to a 2.0:1 or a 2.2:1 or should I go down to the last prop available at 20 pitch. Is there any difference between those two solutions. Props are obviously cheaper to change.
Top speed is not as important to me as holeshot.
