Should I buy 2000 Johnson 130???
VanillaGorilla
Hello ... first time on the forum. I am about to buy a used boat with 2000 130HP Johnson 2-stroke outboard (model J130VXSS). I have heard some mixed opinions of these motors (heard that some of the newer Johnson motors have design/engineering flaws ... not sure if it includes this particular model). Does anyone have some insight as to the pros/cons of buying this motor? Would you advise me for or against buying? Thanks so much!
Cricket Too
Re: Should I buy 2000 Johnson 130???
VanillaGorilla......Welcome to the forum. I think maybe you are confusing this motor with the early Evinrude Ficht motors. The Ficht's had some problems fromm 99-00, but the Johnson's remained carbed and basically the same design as always. They had some carburator issues, but at this point I wouldn't worry about it if that motor has been running. Have you test driven the boat? How does it run? Try testing the compression also, that will give you a good ides what's going on inside the motor. As far as I'm concerned Johnrudes are the toughest motors out there. Good Luck.
VanillaGorilla
Thanks for the info MMC. No, haven't test-driven the boat yet. I've arranged to do that this weekend. You may be correct about me confusing this motor with the FICHT motors. Funny, you are in LI and I am there on business travel right now ... near Hauppauge. Thanks again for the advice ... think I am going to buy it if all is good this weekend. :)
93bronco
Ensign
if it was taken care of you will like it
