Shorten shaft
Door.Co.Ed
I've got a 1968ish Wards Sea King 20hp outboard. Had the shaft extended, now would like to reduce, BUT did not keep any old parts. ARE there parts to reduce, or just remove the 5-6" extension?
Welcome aboard. Start unbolting and check
brim_buster
If its like a johnson/evin the water tube had a rubber piece that connected the water tube extension to change to or from long to short shaft.
steelespike
That would be a Chrysler.Probably need some parts.Take a look or maybe make a jack plate.
brim_buster
my bad I thought that 8 was a 0. got bad eyes lol without my glasses.
gm280
Two issues here. First, whenever you make a change to anything, you always keep the old parts just in case. Second, why not buy another engine and then when you need a longer shaft size again, you will have an engine already to go. Nothing wrong with owning two OBs. JMHO!
oldboat1
^^^second that. big believer in parts motors (some that turn into runners).
