Re: short shaft long shaft
Hi Bob,
Boat manufacturers have some variation between brands and models as to what "short" or "long" shaft measures out to. Hull configuration, keels, etc. can make a difference in how a motor's lower unit will cut the water. With that in mind, motor manufacturers leave in a little bit of "buffer" by making the shaft length a little on the long side so that their motors can be used on different brands of boats without modification needed. The standard shaft lengths are more of a minimum than a set-measurement. .ie, your 18-inch is considered a short shaft, as it falls between 15 and 20. Your 23-inch motor is a long shaft, as it falls between 20 and 25.
You can "alter" your shaft length by setting the motor up higher on the transom when rigging. This may involve some testing on your part to see where the motor is happiest and performs the best, keeping in mind that you want to maintain cooling and propeller bite.
- Scott
