Short/long shaft ?
rjjmsj
If I DO change motors, can someone explain what exactly is the difference in long versus short shaft? Are we talking about the overall length the prop sit DOWN in the water, or the length of the shaft the propeller rides on? <br /><br />If it refers to the amount of the engine that sit DOWN in the water, is there any reason my little boat can use either engine? Obviously an engine that sits deeper in the water, will hit bottom before one that sit shallower...is this the only concern? <br /><br />Or to put another way, is there some formula that determines how far the prop should be below the bottom of the boat's hull?<br /><br />Rob
Dhadley
Re: Short/long shaft ?
Simply measure the transom height. That will tell you which motor is correct for your boat. 15", 20", 25" or 30".<br /><br />Good luck!
rjjmsj
Ok, I measured the transom height, and it is 20 inches. So, if I wanted to be sure I have the right engine for my boat, what portion would I measure (of the engine that is?, ie. from where to where?
JB
Hi, RJ. Measure from the point on the mount that sits on the top of the transom to the anti-ventilation plate (usually called a cavitation plate) just above the prop. <br /><br />That probably wouldn't be necessary, because any "long shaft" engine will fit a 20" transom just fine. I am surprised yours is 20". I thought I remembered you saying you had a pretty small boat, and they usually have 15" transoms.<br /><br />Shorts are 15", Longs are 20", Extra Longs are 25". I don't know what they call those 30" units, except they are usually great BIG muthas. There are small engines made for sailboats that have pretty long shafts, but I don't know how long.<br /><br />Red sky at night. . .<br />JB :)
