Need your suggestions.
1) Does my repair seem reasonable?
2) Should I get rid of this roller trailer and get a bunk style due to the "dents" left by the rollers?
3) Should I be removing the battery and fuel tank during transport?
I bought a used 14' Lund with Shoreland'r trailer this spring. I've used it a few times locally. This is my first boat.
It's a 1995 Shoreland'r R148 trailer that pulls my 14' Lund around. On my way home last night the roller bracket assembly collapsed on the passenger side. I didn't realize it until I got home, 12 miles away. Fortunately no damage to the boat. The boat is not too heavy for the trailer. Sure, the battery is 60 pounds and is located at the rear. I shouldn't have to remove that for trailering or should I? The gas tank is another 40 pounds and that too is in the back.
It is a roller trailer, with a pivoting cross member across the back that the rollers are attached to. There's a 1/2" bolt on each side that holds this cross member to the trailer frame. This bolt sheared off and boat fell onto to the frame and fender. After checking things out today, the folks that designed this should have their head examined. The bolt is one thing, but the frame where this bolt passes through is not built to hold the weight of the boat and the dynamics of being transported. Not a good design. I see that this has come up before.
I'm considering a mod that I hope will work. I will have two upside down |_| shaped pieces made from 1/8" steel, with a hole for the bolt. I'll place this on top of the frame and its holes will line up with bolt that is used. This will place the load where it belongs, on top of the frame. I'll need to have the cross member cut and shortened as well to make room for these. The reason I'm considering this is because I don't have to take the boat and trailer to a fab shop, and these pieces could be replaced if they wear out. Thoughts?
I can see why a bunk trailer would be better for the boat. With the rollers off the hull, the "dents" they've left behind are visible. That weight, supported on 8 relatively small areas causes that. Maybe I should get a bunk trailer. Should I be concerned with those dents or no?
Here are pics of the broken trailer
![IMG_1129-600.jpg IMG_1129-600.jpg](https://forums.iboats.com/data/attachments/174/174168-189f2c10b1d9efad3536dcd9ead65488.jpg)
![IMG_1128-600.jpg IMG_1128-600.jpg](https://forums.iboats.com/data/attachments/174/174167-733e0c2708ed804c96652b3bcced801d.jpg)
Thanks!
Thanks!
