Re: Shore Power Cable Adapter
Jack has given you good info. My thought is a 15amp adapter has less capacity, but will have greater flexibility as far as plugging it into other outlets should the need ever arise. Should work with 20-amp service, too, if 15-amps works within your needs.<br /><br />BEFORE you plug anything into shore power, you need (not should
NEED) to check the safety grounding. Buy yourself one of those little LED circuit checkers and stick it into the shore service BEFORE you do anything else. If you dont get the LEDs to light up in a pattern to indicate the grounding is correct, STOP! Do not take the shore power onto your boat until the grounding is corrected.<br /><br />AC power is very special on a boat. On terra firma 120vac will definitely wake you up if you connect with it. On a boat/water, it can put you to sleep, permanently.
