I Can fix cars all day long. Never been in a IO so I paid some one else to replace the impeller in my 86 alpha one IO for manintence. The boat was sometimes running hot but not over heating. I did this so I would not have problems on my week long 4th of july vacation. I got the boat back and sometimes the water will come up and some times the water will not come up from the IO. Sent the boat back to the shop where they had replaced the impeller and a shaft for the impeller. . They sad it was woren never looked at it myself. The shaft cost $125 had them replace it . So they took my boat back to the shop they pulled it apart and found nothing wrong with it. they ran it on the muffs no problems put it in the lake and sometimes it works but sometimes it does not . To day it did not work so I pulled off the hose from the IO to the warter pump housing. I sucked up the water by mouth then it worked till I shut it off. The shop is taking it back tomarrow they dont have a clue. has some one ever had this problem ?
p.s. ruin my vacation::devil:
