I'm looking for the seal and O ring that go in the top end cap on the lift cylinder on a 1988 Force 125. It's the cap that has the four holes in it that you take out with a pin wrench.
I've found the bigger rings that go on the ram piston and the outside of the top cap.
I'm still looking for the beveled seal that the shaft goes through and the small O ring below it.
