gotchacovered
- Mar 15, 2009
- 17
I have a late '60's 120 merc that I'm having trouble shifting into reverse. It has the old control that has a seperate neutral lever that needs constant attention to keep engine running slow enough to shift. I think the main problem is the throttle cable and the shift cable are out of sync with each other. When I shift into forward I have a large dead spot of travel before the rpm's pick up but when I shift into reverse the the engine is revving up as its trying to shift. Is this an adjustment? If so where is it made? Inside the control? Thanks in advance for help. I'll be looking at manuals at work tomorrow also.
