Hey guys wanted to ask you another question. I have a 1990 Johnson 140 VRO. I am using a 1973 Evinrude shift piolt. Last spring I developed shifting problems, (Enigne not going in to neutral, foreward or reverse.) Easy fix found the 73 shifting cable needed to be replaced. Now after de winterization I tried to fire it up with the new cable. No luck. Here is the problem When I shift the cable, it is going into gear, the prop locks, then I put it back in netural to try and start. I checked to see if it was still in gear the prop is now spinning freely, but no turn over, I have to wiggle by throttle control in the netural positon to get into start to trun over, but then no fire. I can't figrue it out?? If the prop is spinning the engine should be in netural right?? Any ideas, do I need to adjust the cable more?? Is it the box, please help??
