MJS
- Jun 4, 2009
- 124
E25teerc '94 25hp
If I turn the dial on the cable I can get the boat to shift in and out of gear as it should but it won't start because the neutral safety switch isn't allowing it to start. So the way it been since I've had it is that it goes into forward and reverse fine but to go to neutral from reverse I need to go slightly into forward position before it goes into neutral. Is there any adjustment on the switch itself?
