irondovetail
- Jun 2, 2013
- 3
Have a 1995 40 hp Mariner Tracker engine that needed a new water pump impeller. Put engine in forward and dropped lower unit and changed impeller. With a little effort was able to reinstall lower unit. ( Had to rotate prop to get drive splines to aline.). However, am now stuck in forward and cannot shift into neutral or reverse. Have dropped the lower unit and tried to move the shift lever control from forward to neutral and back into forward and raised lower unit again. Still nothing. Any suggestions on how to properly reinstall would be appreciated. Splines on shifter in lower unit look good. cannot see upper shaft, but believe it is in the plastic housing when raising the lower unit. To get the last 1/4 inch or so of lower unit closed have to snug the stud nuts, but they go up easily without more than a few pounds of torque. Am at a loss of what to do next.
