Boats-A-lots
- Jul 22, 2012
- 366
I have a 89 SeaSwirl Cobra 4.3. Three years ago the shifting became hard, so I took it to a shop and had the cable replaced. It didn't really shift smoothly, and has got worse over the years until last week end it wouldn't go into reverse, and then it wouldn't come out of forward.
I removed the red lower cable from the motor, and the shifter moved smooth as new. I pulled on the plastic end to see how much force it took and the cable broke off inside the plastic housing. (so I need a new cable now for sure). Motor running or not, with the cable hooked up, it was hard to shift.
So, (have more time then money now) I pulled the outdrive to replace the cable. (reading the threads on here on how to do that). As soon as I pulled the outdrive off, I could move the cable with one finger. (with it on, it was hard to move). So, now I'm thinking it's not the cable, but the shifter rod? Is this fork looking head suppose to move up and down easy? I can see rub marks on it.
