The lower end oil was milky and oil leaked from above the lower unit when it was laid down, so I am trying to remove the lower end to pressure test it and most likely change the seals. I have all the boats removed, including the two on the shifter linkage. I beleive this linkage is the only thing holding on the lower end.
Can anyone advise please how to disconnect the linkage? I've tried tapping the lower end, applying WD40 to the linkage, and twisting the blade of a flat screw driver between the upper and lower halves of the linkage.
