Re: Shift to forward gear if engine not running
Thanks rodbolt, that sounds like a typing session.<br /><br />p8-63<br />Mechanical Shift, Shift disconnect under lower carb<br />70 HP 1976 and 1977<br />75 HP 1975 thru 1977<br />All units 1978 and on<br />Description<br />The lower unit covered in this section is complete mechanical shift unit.<br />A shift cable conencts the shift box to to the shift linkage at the engine. A shift rod extends rom the engine down thru the exhaust housing to the lower unit.<br /><br />Shifting into forward, neutral and reverse is accomplished directly thru mechanical means from the shift control handle thru the cable and linkage to the clutch dog in the lower unit <br /><br />........................<br />..........<br />Troubleshouting <br />Prelimnary Checks<br />.................<br />...........<br />Now follows some test procedures shifting in all gears, checking lubricant fluid in lower unit<br />and then the sentence<br />"Remember, .......!<br /><br />That's enough ??
