Magic Dave
- Jul 6, 2012
- 4
Hello all. I have owned several boats but I am new to this forum.
I (almost) took my boat out today but I had a shift cable failure before I even left the dock. I have a 2001 Glastron SX195, 4.3 with an Mercruiser Alpha One. Great Boat, clean, very low hours.
I've been trying to remove the shift lever so that I can take off the quadrant, however after about an hour or so I have given up. I can't seem to get the lever off. Apparently there should be a set screw under the lever. I found a hole for a set screw that lines up with a white hash mark on the cover at about the 4 o'clock position. It has threads but no sign of a allen screw in that hole. When I wiggle the lever I can see the shaft move through that hole so I am sure that there is no allen screw in there.
Here is what my particular shift assembly looks like.
![IMG_2467[1].jpg IMG_2467[1].jpg](https://forums.iboats.com/data/attachments/132/132547-8475aa5524cea2e7c051e37dd65fd3e0.jpg)
