I have been working on a 1987 searay this winter with a mercruiser outdrive, alpha gen1. I am now in the process of reassembling. I have replaced the gimbel ring and bearing and bellows and everything in between. I have never done this job before and it has been quite the learning experience. I have just reinstalled the bell housing and I noticed that the "shift lever" seems loose and I thought that I should probably replace the oil seal on this, should I replace the shift shaft as well it has some wear. Also what about the brass bushings, should these be replaced, do they just tap out? Also with my new trim limit/position kit it does not show the clear washers being installed under the sensor that came off of the old units, do these need to be there? thanks in advance.
