surphrat420
- Sep 30, 2003
- 30
I was getting water into the LU after replacing the water pump kit. Im just a driveway wrench'er but i thought i did the kit right. So I pulled the LU and did a pressure test using soapy water. I found the leak comming from around the shift shaft. My question is, I know I need the manual anyways, but can i get away without it this weekend while i fix it? I read, elsewhere that if the shift rod comes out the gear housing has to be totaly disasembled, to get it back in? Does the rod have to come out to change the seal? or is the seal external, and can be changed fairly easy?<br /><br />thanks in advance for your advice ...
