Re: Shift Shaft Linkage
RP, sorry for the delay, the first pix look to me like the rod was the right/left offset
the manual states, place the shift rod in neutral use shift rod gauge P/N 389997,
hear are the specs
long shaft 1975-1981 = 20 29/32" +/- 1/32"
short shaft 1975 on = 15 29/32" +/- 1/32"
this measurement is from the mating surface of the L/U to the top of the shift rod hole
a good starting point is tighten finger tight, and then 2 1/2 - 3 1/2 turns out
nowhere in either manual does it describe the position of the rod, but in some very vague pix it shows to offset facing forward, toward the carbs.
hope this helps
