I read somewhere that the adjustment was 9 turns. Is this correct?
TigerSharkCrazy Seaman Joined Jun 13, 2006 Messages 72 Sep 12, 2007 #1 I read somewhere that the adjustment was 9 turns. Is this correct?
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Sep 12, 2007 #2 Re: Shift shaft adjustment xp200 Evinrude? Im not sure in terms of "turns". The manual will give you a height from the shift rod connector hole to the surface of the gearcase. The tolerances are pretty tight, I wouldnt trust a "turn" method.
TigerSharkCrazy Seaman Joined Jun 13, 2006 Messages 72 Sep 12, 2007 #3 Re: Shift shaft adjustment xp200 Evinrude? Do maybe have those specs?
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Sep 12, 2007 #4 Re: Shift shaft adjustment xp200 Evinrude? What year? Any long shaft?
TigerSharkCrazy Seaman Joined Jun 13, 2006 Messages 72 Sep 12, 2007 #5 Re: Shift shaft adjustment xp200 Evinrude? 1986 XP Evinrude with a 20 inch mid.
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Sep 12, 2007 #6 Re: Shift shaft adjustment xp200 Evinrude? E200STLCDR 1986 or E200TXCDS 1986
TigerSharkCrazy Seaman Joined Jun 13, 2006 Messages 72 Sep 12, 2007 #7 Re: Shift shaft adjustment xp200 Evinrude? Sorry it's E200sltcdr
