i have a 110 hp 1989 evinrude i did the water pump the other day and the shift rod turned on removal so i turned it back to where i thought it was. so i put it back together it goes into forward reverse and neutral no problem. my question is if the shaft were to short would it allow the engine to slip into neutral under full throttle ?
