Re: Shift rod coupler - 1962 28h Johhny
If that recess in the top of the shift rod does not line up with the bolt hole, then the threads on the bolt itself will get rounded/stripped, and they will damage the threads in the connector. You may get the bolt to tighten once, but with the recess not lined up with the hole, the shift rod will not be positioned correctly, and the motor may not engage correctly into gear. That shift rod length is pretty critical in proper shifting of the motor, and if not correct, can cause damage to the clutch dog and gears in the gearcase.
