shift linkage problem
jayvaughn
I have a 1998 force 120 I just change the water pump on... The shifter was in neutral when the lower unit was dropped. Put the impeller on and due to a lack of my knowledge, I turne the shifting rod in prior to putting the lower unit back on. Now when I start the engine, the prop spins because it is in gear even though the shifter is in neutral. I took the lower unit back off and no matter what position I turn the shifting rod to, the prop stays engaged to the prop. How can I know it is neutral before I put it back on?
